Home > Technical (L322) > CTEK charger question
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Anyone got one that can confirm below..
The 12v plug in part of mine has left the red plastic collar in the 12v socket in my boot where I keep it charged,
Can any tell me if I need this red plastic piece or can it be used without it?
Battery was a bit sluggish this morning and I'm wondering if where this red plastic piece is lodged in the 12v socket if it is depressing anything in the 12v socket and causing a drain?
Plug with red piece missing
Red plastic piece stuck in 12v socket
Red plastic piece on plug as it was originally
Post #424260 22nd Jan 2017 3:25pm
Giantlandyman
I think the red collar is so the plug can be used on more than one type of socket e.g. standard cigar lighter and 'NATO' type socket which is a lot smaller. It shouldn't cause any drain if left in because the collar is plastic (non-conductive) and the rear socket is permanently live anyway.
Post #424267 22nd Jan 2017 4:46pm
J evro
Ah right, so it needs to come out and maybe I should glue it onto the plug part then ya reckon?
Post #424269 22nd Jan 2017 5:04pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
The red collar converts between. Din and cigarette lighter plug, so without it you have a Din plug.
So yes you need to retrieve the plug, I assume you have tried plug it back in and hoping the red collar comes out.
Post #424276 22nd Jan 2017 5:48pm
J evro
Ok thanks,
Retrieved the red piece now, but each time I put in/ take out it leaves the red bit in there, wondering if a bit of glue might keep it in place?
Post #424292 22nd Jan 2017 6:49pm
mjdronfield
Does it not like turn to lock in place? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #424307 22nd Jan 2017 8:28pm
espaceboy
glue works fine
Post #424310 22nd Jan 2017 8:34pm
J evro
Not that I could see, does yours ?
Post #424314 22nd Jan 2017 8:42pm
