Home > Technical (L322) > Rear camber adjusters
dolph34
Hi , need to replace the EPB so have to drop rear suspension, would anyone know the part numbers of the rear suspension camber adjusters and bolts please. Also any advice on what else to replace while rear suspension is dropped would be appreciated. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #424501 24th Jan 2017 12:07am
At 10 years old I'd check your subframe mountings they are a huge lump of rubber and don't last forever... Thumbs Up
Can't help with part numbers, they are dealer only so if I were you I'd ask Dan at Duckworths to send you them, sure they were less than £20 for two bolts 2 washers and two nuts when I bought some... Pete
Post #424505 24th Jan 2017 12:15am
holidaychicken
Re: Rear camber adjusters
Microcat site will list them, it's something like www.lrparts.ru
Post #424520 24th Jan 2017 1:40am
dolph34
Thank you both , the guys i use for parts sent me the diagrams and I've ordered all new bolts and washers + nuts and the rubbers ( called insulators ). Im off to the uk for one of my daughters 16th so its being down then.
Thanks again 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #424611 24th Jan 2017 7:43pm
