Home > Technical (L322) > iid fbh
vmaxer
United Kingdom 2003 Range Rover Autobiography Td6 Cairns Blue
iid fbh
hi peeps just wondered if the iid tool does any diagnostics on the fbh re;test faults turn on thanks Thumbs Up
Post #425983 2nd Feb 2017 1:44pm
alistairh
It's got options for turning on and off aux/park heating..
Post #425985 2nd Feb 2017 2:07pm
TomCobbly
This is what the iid manual says:-
4.7.5 Fuel Burning/Auxiliary Heater (L322-10, L319, L320)
Fuel Priming
This routine will remove air from the system (if present) replacing it with fuel.
Check Operation
This routine will activate the fuel burning/auxiliary heater regardless of the ambient and engine
tem- peratures. This routine will begin by clearing faults stored in the ECU. If the routine fails,
proceed with a read fault and fix the issue.
Usage
These functions are useful to get the system up and running after a long period of inactivity, when
replacing the unit or simply to diagnose a problem. 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #425987 2nd Feb 2017 2:29pm
vmaxer
Rolling Eyes mines 2003 td6 so that,ll be a no then.
Post #426000 2nd Feb 2017 3:48pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
It will read the the FBH faults on your car, and you will be able to reset them providing the fault (if any) is no longer present!
Post #426059 2nd Feb 2017 10:16pm
