Home > Technical (L322) > Brake lights on ignition off
Typical, flamin' snow now! .
Post #462283 27th Dec 2017 9:55am
DEAD FFRR Saga
Had a few days of busy family time, was able to get back to the dead FFRR this morning. I had had the LCM and the brake light switch in the airing cupboard for a couple of days...
Disconnected that +ve battery terminal and touched with the -ve lead (supposed to help clear ECUs)
Reconnected LCM and brake light switch
Reconnected battery - no whirring noises, no flashing hazards (remember alarm siren disconnected)
Key to ignition, car starts first time Thumbs Up
Did wheel to wheel to clear dash lights, no complaints or bongs from the dash
Connected up the IIDTool and ran a full diagnostics. The usual suspects showed up along with the complaints I would expect to see from a battery disconnect. BCM had a pile of faults on the passenger door. Of note:
BCM - Aux Input Fuse defective (what is this?)
Instrument Pack - Chime T1 Fault / Lighting Module 0xBE
Lighting Module - NO COMMS with ECU !!
Parking Module - NO COMMS with ECU !!
Steering Lock - Rotation Detection 0x45 / Intermittent Relay 0x18
Cleared all faults
Live Values:
Brake Light Switch - 0.4/5 volts
Alternator bang on 14.0 volts, has been the same for years. Battery was 12.5 volts before reconnection.
So looks like i need to sort out the Comms with the LCM or get the LCM fixed.
Also of note, when I locked the car the flashers didn't flash (because siren disconnected?) - tested all lights, they all work, including indicators.
Now waiting for the car to go to sleep, see if it faults out again. At least I moved away from being parked up close to the wall of the house so I can get at both sides (e.g. access the BCM) .
Post #462790 31st Dec 2017 1:22pm
24 hours on and all seems well. No alarm going off, no stop lights on.
Unlocked with remote, flashers have returned !
Started up, connected up IIDTool, LCM ECU has returned !
Cleared all faults, took for a little drive.
Now parked up, on charge.
Censored thing Laughing
Found a good place for Brake Light Switches
https://www.onlinecarparts.co.uk/car-brand...html#10439
(Europarts currently asking 3 x the average price in the link, not sure what one from LR is)
LCM Repair Shops on EBay
https://www.ebay.co.uk/itm/Range-Rover-L32...Swry1aBCZb
https://www.ebay.co.uk/itm/Range-Rover-Lan...SwyQtVxMQv .
Post #462863 1st Jan 2018 11:55am
Think I am going to have to put this one down to these guys:
Famous Last Words has been impeccable all week, although I think I may have a mild battery drain as I am getting HDC Inactive on every startup and don't seem to have the juice it used to? Maybe I need to reconnect Battery 2 (tempting fate!) .
Post #463344 4th Jan 2018 11:12pm
