![]() | Home > Technical (L322) > Rear Boot seal |
| tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343
Are you sure you don't have a build up of mud / leaves / general crap on the top of the seal as I did when I had a similar leak. It was like a dam and the water was coming into the car. A good clean and it's been dry for nearly two years! |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3668
I got a genuine one from Dan@DuckworthParts... he has his own slot on here! I think it might have been cheaper than Britparts!! Give him a message and then decide |
| muddy_v8 Member Since: 08 Feb 2017 Location: Hampshire Posts: 20
No 100% it's clean and clear in that respect, the seal is broken down inside the rubber not gripping the ridge tightly |
Perfect thanks, I havnt posted enough to be able to PM yet though Is he on the www ? |
| Mike.Boro Member Since: 09 Dec 2013 Location: Middlesbrough Posts: 44
Muddy, I got a new seal from Dan last November, £84 with the VAT. Click the link at the top right of this page under Sponsors for Duckwoths. |
Or post your request here!!
Perfect ! Thank you guys |
| lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269
Some of Britpart stuff is pretty low generic quality, especially their rubber components, Be careful, check to see if it is a. O.E part Britpart bagged or just a pattern part |
