Home > Maintenance & Mods (L322) > Rear upper suspension arms - big job?
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Had the following advisory's on my TD6 (covered 110k miles) in December, and now theres a knocking/ rattle whenever you go over a bump, is the following a big job to do? And if so, what can I expect to pay (non main dealer)?
offside rear upper Suspension arm has slight play in a pin/bearing (2.4.G.2)
nearside rear upper Suspension arm has slight play in a ball joint (2.4.G.2)
Thanks in advance guys
Post #429141 25th Feb 2017 4:28pm
Macca314
United Kingdom 2011 Range Rover Vogue TDV8 Fuji White
Hi
If it's a knock it will more than likely be the little link arms on the rear antiroll bar easy enough to do.
If it's a squeak when mounting the kerb etc, spray some Wurth penetrating oil onto the upper and lower rubber bushes one at a time until yo elicited the squeak. I did this on my Td6 the bushes can be knocked out with a good hammer, or look in the Rave Disc and make a bush puller. What is you tyre wear like? That will give you a good indication if the bushes have worn.
Good luck
Post #429158 25th Feb 2017 7:18pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
The rear upper suspension arms on the front are quite an easy job to do.
However, it is usually wise to change the ball joint at the same time, which is a pita.
What you will pay for it to be done by indy or dealer, I have no idea.
Greg.
Post #429164 25th Feb 2017 7:45pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Have you looked in the spare tyre well to see that nothing is in there making the knock and rattle, I have a beaker bar in there and it bumps and rattles when I go over a bump. Just a thought.
Post #429211 26th Feb 2017 6:54am
See wiki for howtos on replacing REAR bushes:
http://www.fullfatrr.com/forum/topic27263.html
http://www.fullfatrr.com/forum/post140711.html
http://www.fullfatrr.com/forum/viewtopic.p...066a64f102 .
Post #429253 26th Feb 2017 12:47pm
gregdav
Sorry my bad Embarassed
Post #429265 26th Feb 2017 2:39pm
