Home > Technical (L322) > td6 injector failure?
javal322
2005 Range Rover Vogue Td6 Java Black
hi again guys , thought id ask some advice on here , have also asked on the facebook groups but opinions are varied !
anyway , after standing for a few weeks my td6 started smoking on start up and under load , started off quite light so i figured it was just from standing ect , now that its been used more the probem is getting worse and has helped identify it a bit more
im getting grey/blue smoke and a VERY strong smell of diesel from the exaust , also fuel economy is terrible !
seems to be an intermittent fault but getting more regular now , mainly on start up and under load , seems quite clean if revved when standing still
what are your thoughts on this? personally i think its injector failure leaking at the nozzle , its off the road at the moment so getting diagnostics on it would be a problem
its done 175k miles , serviced it last week , cleaned EGR too
problem was present before EGR clean and engine service
thanks
Post #429813 3rd Mar 2017 2:28am
mercs600
England 2002 Range Rover Vogue Td6 Java Black
I had the same as you on start up etc and after a while driving the engine started missing slightly. Eventually it got to a point where I removed each injector electrical injector wiring plug and on No4 cylinder there was no difference in tick-over. Belled the wiring out and proved it was the injector as I was getting the correct voltage as the others and also had continuity. Sourced a refurbished injector off Ebay , fitted it and no further smoke , issues etc.
Post #429815 3rd Mar 2017 2:38am
javal322
on mine the tick over is fine but fuel economy is bad , it smokes and also has a misfire on start up?
how long did it take you to change the bad injector? not done much with theese engines
Post #429905 3rd Mar 2017 8:26pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
I recently replaced my 6 injectors, no more than 3 hours work if they are not stuck. I did them myself., but it depend on how fast you are on the spanners.
Post #429949 4th Mar 2017 2:10am
javal322
thanks i think its the first thing ill look at , bloody gearbox problems now aswel !
Post #430008 4th Mar 2017 8:12pm
miggit
Do the injectors first... I thought my TCC was going again... then 2 injectors all but failed, had the lot cleaned and 2 repaired.. and when I went for a drive with the recon injectors installed the TCC problem had vanished Thumbs Up
Whistle turns out that a misfire can give the same symptoms as TCC vibration Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #430025 4th Mar 2017 10:53pm
javal322
TCC??
Post #430030 4th Mar 2017 11:37pm
miggit
Torque Converter Clutch (lock up un it in the gearbox) Yesterday I couldn't spell Engineer... Today I are one!
Post #430052 5th Mar 2017 10:13am
javal322
ah yeah i know what it is but didnt connect the shorthand to it lol
worried thats also a problem with mine , shes revving a bit higher than id like and takes ages to move in the mornings !
Post #430093 5th Mar 2017 4:55pm
miggit
Low fluid? dirty filter? Yesterday I couldn't spell Engineer... Today I are one!
Post #430106 5th Mar 2017 6:38pm
javal322
just had a full engine service and a full gear and transfer box service too
Post #430254 6th Mar 2017 7:13pm
