Thanks L322 - now a suspension fault. | |
I picked the L322 up from getting a new fuel pump. On the way home it was pulling to the left, but I didn't have time to check anything. I left it for a few days while I was away, on return it seemed a little low on the left. Started up, it levelled itself a little but the ABS or stability control triggered at the bottom of the drive (it's a slight slope down). Then an Air Suspension Inactive. Read the codes, "articulation validity fault". Cleared it, but still a lean to the left. If I put it in off-road it rises fine and seems level, drop to normal and it's level with no pulling. If it drops to motorway mode it's leaning again.
I haven't looked any further yet, but I'm suspecting a height sensor.
However - when they did the fuel pump change they "cleared the codes" with TestBook. Is it possible they accidentally messed with the height calibration? Or is it just a total coincidence?
