![]() | Home > Technical (L322) > Air Suspension not working, no lights |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
For no reason the EAS has stopped working, there are no lights to indicate level etc, this happened I think while car parked, ie on when switched off and noticed next time I used her no EAS, comes up with warning on dash. Ive checked the 2 fuses listed 57 and 88 and both fine.
zoso Member Since: 20 Aug 2014 Location: Ayrshire Posts: 79 ![]() ![]() ![]() |
I had the same symptoms when my air compressor failed. No lights, nothing on dash although the car was sitting pretty low. 2017 4.4 TDV8 Autobiography
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Lights go out whenever a suspension fault has been occurred, and this could be caused by any one of a fairly large number of things. You could try pressing your 'check control' button - that may give you a suspension fault message (but won't specify what the problem is). Better way would be to use an IID tool or other code reader, if the compressor is goosed you should get a 'pressure static when filling' fault. 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
Thanks guys, compressor sounded fine last time I heard it, shes at correct height and has been for the last 2 weeks, only just done the piston ring in the compressor. One day your life will flash before your eyes......................................make sure yours is worth watching!
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 835 ![]() ![]() ![]() |
I think if all of the EAS lights are out it indicates a hard fault and only able to be cleared with an IIDtool or the like..... ______________________________
OK cleared the only fault, reservoir losing pressure and its all working again but the reservoir had not lost pressure as the car stayed at the correct height
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
The reservoir can be losing pressure and the vehicle will stay at correct height due to the front and rear valves locking off. Possibly problem with reservoir pressure sensor or reservoir control valves block, or a pipe leak somewhere. .
Thanks, will I hear air escaping? One day your life will flash before your eyes......................................make sure yours is worth watching!
Depends on where if a leak .
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I was pondering the problem of locating leaks today whilst working on my suspension.
Maybe spray soapy water on it and look for bubbles One day your life will flash before your eyes......................................make sure yours is worth watching!
