![]() | Home > Maintenance & Mods (L322) > Lower side skirt/rocker panel replacement |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
If its the black plastic youre talking about its very easy to replace, all you need is a screwdriver or trim remover tool! Theres 6 plastic bungs eachside you pull out the middle of each and then open the doors and prise them off from the top and the clips come off! If you have front mud flaps there may be a screw under the front corner to remove and off they come. 10 mins at most.
