Home > Technical (L322) > Door openings on engine off
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
Hi Everyone !
Is there an option on a 2012 4.4 TDV8 so that all doors open when you turn the engine off without having to press the un-lock button?
It seems quite easy to open all the doors when entring but I can't find anything that opens everything when you are getting out without everyone having to pull the door lever twice?
Am I missing an obvious solution ?
Thanks I need more help than most...sorry !!
Post #434417 10th Apr 2017 7:07am
if you mean the 'drive away locking' , this can be disabled via the dash menu....
if you want to keep this function then there is no way to automatically unlock the doors when the engine is switched off..... ... - .- -.
Post #434422 10th Apr 2017 8:50am
muppet
Thanks for the reply Stan,
They must have changed it for my vehicle then as my Disco locked the doors when pulling away but auto opened them when the engine was turned off, funny enough the "loan" Range Rover Sport I have also opens all the doors when the engine is off and also locks them when over 5mph....weird !! I need more help than most...sorry !!
Post #434425 10th Apr 2017 9:28am
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I’m glad I’m not the only one to find this odd. Every BMW I’ve ever owned unlocks on ignition off.
Surprised there’s not a coding option for this.
Post #607337 26th Sep 2021 8:23am
