![]() | Home > Technical (L322) > Where is the LCM-Light Control hiden on L322 2003 TD6 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
thanks, I was wanting to check the connections on the ECU as I am getting related fault codes for suspension. and ECU, so thought I might have aC An bus coonetion fault, researching says the various ECUs are interconnected.
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 ![]() ![]() ![]() |
Hey lounge_on_wheels
I would recommend disconnecting the battery to disconnect the LCM, for the avoidance of any gremlins creeping in, and also creating a safe state (for you, the LCM and everything connected to it!
Thanks Joe90
Can't go flat - BONUS! However, ensure your physical key can lock and unlock the drivers door beforehand (leave another door or the boot open when testing) - alarm may go off until you put key in ignition.
If i leave it sat for a week will i have pair up keys or any of that craic afterwards?
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Absolutely no need to disconnect the battery. Had mine in and out a few times over the years. |
Unnecessary quote removed
