Home > Technical (L322) > Supercharged reduced performance |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 422 |
Fuse 7 15 amp is the fuse in the rear that looks after the auxiliary coolant pump. Mine keeps blowing and I've been trying to find out what else is on that circuit.
30th Apr 2017 6:44pm |
Nine times out of ten the auxiliary coolant pump has gone pop , why are you both looking at the fuse first? 2008 MY Supercharged
1st May 2017 10:19am |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Our 2007 SC suffered a loss of power on the motorway and the reduced engine performance warning light came on. This was diagnosed as being due to a defective water pump which serves the supercharger. The water pump was replaced an the problem was resolved. |
1st May 2017 10:28am |
I'm not and the OP was asking about the fuse, so I told him. My pump was changed last October and, due to the fact I was still getting reduced engine performance, the wiring was looked at again in January. I still got reduced engine performance warning so did some research and found that a fuse, in the rear, can cause problems. A little more research and I found that fuse 7, protects the pump and mine was blowing every time the ignition was turned on. The research is not helped by the fact that the fuse box diagram in the handbook, is different to the actual car; significantly. That's as far as I've got so far and I'm trying to identify if there's any other electrics being protected by fuse 7. I need to eliminate everything else to identify if the pump is no good. 2017 5.0 Autobiography Supercharged 2005 Merc SL350 2017 Abarth 595 Comp 180 bhp 2005 Disco HSE 2.7 oil burner |
2nd May 2017 1:52am |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
I had a pump failure on mine that gave me that warning.
2nd May 2017 7:54am |
Skylinejgtc Member Since: 19 Apr 2019 Location: Bradford Posts: 2 |
Sorry to bump this thread but did you find a resolution to your issue, i am having problems with my Aux coolant pump as it doesnt seem to be getting a 12v with ignition on or when started? |
18th Aug 2019 2:17pm |
My indy ran a new cable from fuse 7 to the pump and no longer does the fuse blow hence the pump works all the time, as it should so no more reduced engine performance. 2017 5.0 Autobiography Supercharged
18th Aug 2019 3:05pm |
Thanks a lot, thats basically what i needed to know, is that fuse 7 in the boot fuses?
18th Aug 2019 3:10pm |
Yes, it is and everytime I started the engine it blew. The new cable was added which sorted the problem. 2017 5.0 Autobiography Supercharged
18th Aug 2019 3:16pm |
