Home > Technical (L322) > Engine Failsafe, Trans Failsafe HDC OFF engine wont start
csufy
Hungary 2004 Range Rover Autobiography 4.4 V8 Buckingham Blue
Hello guys I need your help again..
Ive got a RR '04 4.4 V8 Autobiography.
Yesterday my upper water hose blew. I stopped immediately the engine. After half an hour I refilled the coolant system then started the engine and everything was working normally. Until this morning.
This morning I started the engine it was running smooth as usual. Then just before I jumped in to go out of the garage the engine idle suddenly started to be very lumpy so I stopped the engine.
I tried to restart the engine and it does not start again.
Computer says Engine Failsafe, Trans. Failsafe, HDC Off...
I connected my OBD diag to read the fault codes and the diag device can not find the DME.
What happened? Maybe some water causing a short circuit somewhere from the yesterdays problem?
For the full story I had a fault code "Battery Disconnect Unit 1" maybe its related to this fault.
Any advice?
Post #436646 1st May 2017 6:22pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Is He battery charged ?
I've had similar drastic sounding messages when my battery went flat onetime
Post #436654 1st May 2017 7:35pm
csufy
I measuerd 12,5V.
Post #436655 1st May 2017 7:43pm
csufy
It was a fuse blown inside the box engine department.
Also my thermostat heater cable burnt out. Very nice..
Post #437177 5th May 2017 4:36pm
