![]() | Home > Technical (L322) > live values on Steering sensor please |
| Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804
Where are the live values for the steering angle sensors on the IID Tool, can't find anything for them, just been out and plugged my IID in to read them, but there's no mention in the live data menus. |
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801
I'm home at tea time .. if you haven't had an answer by then I will post up mine 👍 |
| lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269
scroll down on the Live Values, then select Live Values > Live Values ECU > SASM - STEERING Angle > Steering Angle degrees
Hmm, couldn't find that option on my BT IID Tool, will have another look later and may need to get the IID updated |
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
this is what I have, center, full right, full left .
And mine. Left then right
Thank you all for doing that for me, it's much appreciated!. I am trying to trace a fault, iid tool BT sometimes comes up with Steering ECU internal error fault. I had a reading last night of centre 0 deg , right -457deg and left 1456 deg! and then it froze and would not show any reading other than that when the wheel was turned.
Sorry to hijack this thread slightly, but I updated my IID Tool to the latest firmware, thinking I needed that to get the SASM Steering Angle ECU info...but still can't get anything.
Message the guys at gap.. my iid tool was missing the gearbox ecu part..,quick download and it was fixed 10/10 for service... |
| rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318
Can I ask what you would need these values for ? Just trying to biuld up my knowledge of FFRR's |
I wanted to check them against mine as 1 have a fault, I posted I had a very high reading 1000degs more on one side,so wanted to check against others. |
| PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153
In bold, this points to a defective SAS, typical behavior. Discotigger: please try the following: Start the engine, Menu--IIDTool Config--Find ECUs, should make the SAS visible. http://www.gap-diagnostic.com/
Hi Pat,
Will require further investigation, PM sent |
