Home > Maintenance & Mods (L322) > L322 Wing Mirror auto adjust problem
phillips321
United Kingdom 2003 Range Rover HSE Td6 Galway Green
Hi guys,
2003 TD6 with a problem with the wing mirror, when selecting reverse the mirror angles down fine, but never comes all the way back up to the correct position. So each time i reverse it gets worse so that i have to manually adjust it back up.
Is there a way i can force it to remember the driving position? Or any sensors i can adjust to fix this?
I'm aware I can turn it off but i actually like to be able to see the curb on the offside when reversing so like the feature.
Many thanks
Post #440171 30th May 2017 11:13pm
i'd strip it down and see if any thing is worn in there, [strip down info in the wiki].. ... - .- -.
Post #440188 31st May 2017 8:41am
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Mine sometimes dips on reverse, then doesn't un-dip. My workaround is to put it back into reverse then out of reverse again which usually wakes it up. Probably related. 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #440206 31st May 2017 11:03am
CS
I had this on my 2004 car. I think what was required was cleaning and lubrication of the parts inside the mirror housing. Only Range Rovers since 1988
Post #440234 31st May 2017 4:17pm
