Home > Maintenance & Mods (L322) > fan shroud 4.2SC
stucart
fan shroud 4.2SC
Had a go at removing this to get to belts today!!! Removed 2 plastic fixings at top,unclipped air-con pipe and pulled it out of way a bit but cant see what else holds the shroud, fixings lower down??? Any ideas/pics etc tried a search but revealed nowt?
Cheers. Stu.
Post #440425 2nd Jun 2017 12:58pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Stu, If the same as mine 4.4. There is a small screw / bolt half way down on the right hand side & further clips at the bottom. You will need to undo the the lower shields as well. *** what ever you do don't yank it out, as there are connections on the bottom.
Hope this helps.
Post #440426 2nd Jun 2017 1:21pm
stucart
thanks Hr, I'll look underneath and at side, bit more involved than I first thought Sad
Post #440447 2nd Jun 2017 4:46pm
