Home > Technical (L322) > Front left door window fail
Speedster964
Norway 2007 Range Rover Vogue TDV8 Java Black
Please excuse my poor english, i´m norwegian...
My 2007 starting to not bring the window down even I could hear the window motor running and stop at the bottom
I discovered that the mounts/brackets holding the glass had come loose from the window after taking the door side of.
It was only glue from factory on one side, I think that is the reason for breaking loose. Years of small movements with all the load on one side finally brake it loose.
I cleaned the window and the mounts and glued it back together with some epoxy glue for glass.
Post #441404 13th Jun 2017 11:56am
those little slot brackets should be bonded to the glass and through time yours has come apart, nice repair job.. Thumbs Up ... - .- -.
Post #441411 13th Jun 2017 1:01pm
Speedster964
Thank You.
Post #441422 13th Jun 2017 4:13pm
