Home > Technical (L322) > Front door card won't come off.
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
I am trying to replace the drivers exterior door handle cable on a 2006 MY. I have looked at RAVE and got as far as releasing all the edges of the door card but something still seems to holding it on somewhere behind the interior door pull. I have definitely removed the large screw next to the interior catch. I have given it a firm tug but it doesn't want to move.
Any ideas?
Glen.
Post #441894 18th Jun 2017 3:25pm
I seem to remember a big nasty clip in the middle of the door, which required a mighty tug, but this might the the rear one. I found it easier with the window down. .
Post #441918 18th Jun 2017 6:46pm
GDM
Joe,
There was, indeed, a large clip in the centre of mine which eventually came free when I gave it a really good tug upwards.
Turns out that my cable wasn't broken, the outer had just come unclipped at the exterior handle end but I fitted the new one anyway.
Getting the card back on was a pain, eventually realised that the window seal had to clip on first but it was still rather tricky to get in place. Unfortunately the plastic lip next to the window/mirror switches cracked slightly when the card came off, so that clip is not holding particularly well.
Glen.
Post #441949 18th Jun 2017 11:14pm
alistairh
I've had both of mines off countless times and it's always been a pain refitting and getting it to fit as it was. I had excact the same issue with the window strips. I ended up buying a load of those yellow popper clips and replaced them as they go flimsy. Door cards sit perfect now..
Post #441951 18th Jun 2017 11:36pm
Thumbs Up .
Post #441952 18th Jun 2017 11:37pm
GDM
Mine are mostly white clips, except for one black one just below the mirror which broke up. That coupled with the cracked lip near the window switches has left it less than 100%. I will have another go at fitting it with some new clips and maybe try to glue the cracked plastic.
Is there a website where I can look up the clip part numbers?
The videos of removal make me laugh, it really isn't quite as easy as they would have you believe.
Post #441953 19th Jun 2017 12:31am
alistairh
Eyc000360 is the part number for the clips. 👍
Post #441967 19th Jun 2017 8:55am
GDM
Thanks. Are they all the same? I seem to have one different on near the mirror.
Post #442042 19th Jun 2017 10:34pm
alistairh
I have the same. I haven't touched that one tbh.im sure the other ones are used in all l322's. Mines had crumbled and there was no way they could hold the door card on tightly...
Post #442056 19th Jun 2017 11:47pm
