![]() | Home > Technical (L322) > Key Ignition |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Hi Try a batery disconnect - deails in the Wiki top right - always worth a attempt for electical gremlins (resets the computers etc.)
alika808 Member Since: 02 Jul 2017 Location: 21.3069N,157.8583W Posts: 4 ![]() ![]() ![]() |
Battery terminal disconnected but still doing the same. Anyway, I can't find (Wiki) the same issue I have. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Wiki here
I checked out the wiki but there's no topic about my issue. I am hoping someone have been experienced my problem. |
Have a look in the left hand rear cubby in the boot, and check connections for DVD/Radio/TV etc, make sure these are all clean and dry.
I am suspecting it's the ignition switch because even the key is out from the ignition switch, still sensing that the key still in. Also, the logo still displaying at the radio because it is still sensing the key in the ignition switch. I am search to replace the switch. |
