Home > Technical (L322) > Vehicle raising slowly MY07 S/C
quavey
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Evening chaps, first time today my old girl has given any bother. I've done a bit of research and its pointing towards a weak compressor however I'll just explain today's events.
We drove to a classic car show 15 miles or so up the road, car behaving perfectly. The field was a touch rough and I put it in off road height (probably not needed but why not...) to park. Soon parked I sent it straight down to access height get my little boy out.
After returning to the car 4 hours later or so I started her up and put it straight back into off road height to get back out of the field and it seemed to take a long while to raise up, so long in fact the vehicle reported "Vehicle raising slowly" once. It did make it and drove home absolutely fine. Once we had got home and parked on the drive I tested it again and it went straight up and back down again with no problem, delay or messages like it always has done.
Now the field did have some quite bad ruts etc, did this confuse it? Or had I caught it off guard and used the contents of the tank changing height in the field? Is this something I need to investigate further or just put it down to one of those things and see if it happens again? Can an MY07 compressor be rebuilt or does it have to be replaced? 2005 E60 M5
2006 (MY07) L322 4.2 S/C
2024 i7 xDrive60
2004 L322 4.4 Vogue, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C , 2001 P38 Vogue, 1999 P38 4.6 HSE.
Post #443348 2nd Jul 2017 10:10pm
That's pretty normal, in a short space of time you put it to high, then to fully low then asked it to go to fully high again. And the reservoir didn't have chance to recharge.
It raised slowly because it was lifting on the pump. Not in the air store. There is nothing that can't be fixed with a hammer😜😜
Post #443351 2nd Jul 2017 10:34pm
quavey
Good to know cheers mate. Will keep and eye on it, I don't actually use the air suspension much in it. It's a weekend car for us for days out as a family. However I can see the logic in that it didn't have any time to rebuild any air pressure between the suspensions height changes. 2005 E60 M5
2024 i7 xDrive60
Post #443352 2nd Jul 2017 11:29pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
As has been said, seems perfectly normal Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #443359 3rd Jul 2017 8:32am
