![]() | Home > Technical (L322) > engine fan coming on even when cold? |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
hi guys
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
Do you mean the engine cooling fan? |
sorry yes the engine fan, i have just started it up from cold and it started running straight away; im assuming that it will normally cut in from time to time and not constant ??, as you can here it when it cuts in, and it didnt cut in as much before,
hi
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Bleed valves:
hi joe
Darryl72 Member Since: 25 Oct 2016 Location: East Sussex Posts: 62 ![]() ![]() ![]() |
diesel Dave has described exactly what mine does of recent weeks, fan comes on when cold start, from the previous journey and very shortly shuts off, glad this thread is here as I was thinking it may of been an issue.....but you know these old girls , they don't often go wrong.....!!!...!!! Lol |
They would most likely have removed it just for ease of access.
hi joe
I'm not sure about the TD6 but the fan on the Petrol variant (certainly the AJv8) is controlled thermally and also with an electronic lock up clutch.
No need to drain down. You have to "release" the shroud in place in order to get enough room to get the spanners in place. It is a bit of a fiddle, but once you break the lock of the nut on the pulley, the fan should just spin off, then you can pull it up and out, leaving the shroud in place.
Unnecessary quote removed
