Home > Technical (L322) > 200psi cap
alistairh
200psi cap
My caps starting to fall to bits internally causing a slight leak of coolant..can only seem to source 140psi caps which I thought were for the diesel Fattys..shall try duckworths on Monday but in the meantime if anybody has the v8 petrol what pressure rating is your cap?
Post #444628 15th Jul 2017 9:43am
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
The parts catalogue I always use is showing they are the same cap for all L322, which is part number PCD000070
Not sure if this clears things up, but i'm guessing 140psi is the right cap, as they all seem the same!
Post #444646 15th Jul 2017 1:28pm
Stacker
Update: https://www.landyzone.co.uk/land-rover/whi...00.237563/
Take a read of this thread, holiday chicken from on here seems to have posted ??
From what I read it was issued with a 200psi cap, but LR have changed them all to 140psi to try and stop a problem with the tank splitting?
Maybe I take back my last post...
Post #444647 15th Jul 2017 1:32pm
p38arover
Australia
200kPa and 140kPa, not psi. A 200 psi cap would be about 1400kPa or 14 bar (using the approximation of 1 psi = 7kPa)
Use the 140kPa cap.
Mine had a 200 but was changed to a 140. If you look at Microcat, you'll see the 200 was for early models.
PCD100200L 1 CAP, L322 RANGE ROVER to (V)1A001049
PCD000070 1 CAP, L322 RANGE ROVER from (V)1A001050 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #444649 15th Jul 2017 1:53pm
alistairh
Brilliant.. many thanks gents that's a great help 👍
Post #444656 15th Jul 2017 3:59pm
