![]() | Home > Technical (L322) > Anyone put hybrid turbos on a tdv8 ? |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Never heard of anyone using another turbo. I can't see that fitting different turbos would be easy given they operate by an electronic actuator. ______________________________
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Had mine replaced recently and was very surprised how small they are. Would need a remap to cope with extra air and maybe larger injectors. 2015 4.4 AB
Yes the look fairly small, but I suppose there's two of them and each bank is only 1800cc.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2620 ![]() ![]() |
Hybrid turbos aren't some magic performance part, they're just turbos assembled with a non-standard cold or hot side - not sure it's really a valid term nowadays, when you can buy one with pretty much whatever spec you want. |
Gumball3000 Member Since: 11 Mar 2017 Location: Liverpool Posts: 200 ![]() ![]() ![]() |
So would a modified compressor in the turbo not improve the performance ? |
Ive had cosworths and Subarus with Hybred turbos over the years and they all required larger injectors, bigger intercoolers, different ecus, etc. I dont think just modifying a turbo with a larger compressor wheel , etc would be effective becuase the standard ECUmight not have the parameters to deal with more airflow and provide enough fuel to match the increased airfllow.
