![]() | Home > Technical (L322) > Vibration &a transmission/drivetrain... |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
classic signs of torque on converter.
SamUK Member Since: 29 Jun 2017 Location: South Posts: 32 ![]() ![]() ![]() |
Damn! Could be a costly fix then!
40k since replacement miles including towing on a TD6 Gearbox could easy need a new torque converter again.
Ok, I had thought that.. So is that thudding between gears at low speed and rpm also Torque converter related or is that gearbox? I don't want to be changing the torque converter to find out it's the box as well you see.
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 ![]() ![]() ![]() |
It seems Birch's in Liverpool have a good name ?? |
Hi guys..
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 ![]() ![]() ![]() |
Sounds like your box is on the way out....
Exactly those symptoms yes...
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 834 ![]() ![]() ![]() |
I would pm RRPhil he's the only one that can tell you definitively what's wrong with your gearbox and give you an idea of how to remedy it.
My worry would be the friction modifier has cured the symptoms but not the problem....filter and fluid would be the next move id make.
Haha.. I agree, the range rovers are ridiculously comfortable, for a 4x4 there spot on, more comfortable than the new Mercedes Gml 4x4 ( I've been in one) in fact.
Does he do the TD6 box and TC ? How do we get hold of him? |
As I mentioned, pm him on this forum and I'm sure he'll give you some sage advice. He's helped countless members on here.
