Home > Technical (L322) > air Suspension
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
air Suspension
Hi
The air Suspension is not working properly and is on the stops
I have a fault
“too much energy for regulation needed rear left”
I cleared the fault and the rear of the vehicle rose up
I don’t know if I waited long enough but I thought the front was not going to rise so I switched it to off road position, that didn’t seem to make any difference so I switched it to normal road height and the front immediately rose to the off road height.
Both front and rear are now in off road position
No matter what position I put the switch in, the suspension stays in the off road position
At the same time, with the switch in the normal road height, the touch screen shows the suspension in normal height
I put the switch in the lowest position but it stayed in the off road position so I drove it through the gully at the side of the road a few times and it has come down to properly less than normal road height but not to the stops.
I am thinking the problem is
But where do I go now
thanks
Post #446908 7th Aug 2017 4:53am
