![]() | Home > Technical (L322) > HELP!! I need to open bonnet |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1400 ![]() ![]() |
if your cable is connected to the bonnet latches (unclear if you managed to do this)
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
Ok To clarify, the main cable from the bonnet catches is still there,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
someone here recently had to smash the grill to get access to the hinge locks, maybe this is the way to go.. ... - .- -.
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 403 ![]() ![]() ![]() |
I had a problem with one of the catches and managed to pull out the front of the passenger side wheel liner and put a medium sized lever bar up to the back of the catch and release it that way. I'm fairly sure you could do that to the driver's side too. I had another catch knocking about so could see where I had to lever - which helped. Current:
I wish I had a picture of how the cable lays along the top of the inner fender, so when I pull the inner guard off I know roughly what I am feeling for with my hand. Any one willing to take a pic for me it would be greatly appreciated. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
Reaching the cable alongside the wing with the inner wheel arch removed is a bit of a non-starter, the cable is laid in the 20mm gap between the wing and the large electrical box.
Hi Nicedayfor it, I hadn't touched the long cable, only undid the short cable from it , and un-clipped the plastic cover that covers the 2 cable joins, all the rest of the long cable is attached as per factory. so it might prove difficult, either way I have no choice but to try it , as I want to avoid breaking the grille. |
Nicedayforit, your a champ, I pulled the inner wheel arch trim off and put my arm up near the intake pipe and pulled on the cable and the bonnet popped open, thanks mate your a life saver. |
Glad to be of help |
