Home > Technical (L322) > Auto unlocking and unlocking after ignition turned off
Rob199027
Hi there
Got a 2010 ffrr vogue se
Should it have auto unlock and lock ? Also should it auto unlock
Any advice be great or can you change on settings ?
Cheers Thumbs Up
Post #447834 14th Aug 2017 5:45pm
if you have the tft screen then you can select auto lock on drive away from the menu...there is no auto unlock, you have to press the unlock door button on the centre dash or if double pull the door handle. ... - .- -.
Post #447841 14th Aug 2017 6:30pm
