Home > Technical (L322) > Front suspension noise.
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
I know too many odds; my front suspension makes noise on bumpy surface.
But i realised it does not when i go up hill even it is bumpy(same hill noise downward; none upward)
It is a knocking noise as suspension works.
Goes fine straight line corners etc.
May be this can shorten the list?? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #447913 15th Aug 2017 11:04am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Mine makes a repetitive knocking from the offside front shock area and has done for the last 30,000 miles. Nothing visually wrong and goes through a service and MOT without issues.
Have you got a video of it at all?
Thanks Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #447914 15th Aug 2017 11:45am
fisha
My personal experience is that the ball joints wear out, and when they do, they clunk when the wheels hit bumps. It doesn't affect the steering though ... just makes a clunking noise.
Solution: Replace both the suspension arms(which come with bushes) and the ball joints on each side. Its a medium difficulty task depending on how much rust there is. there are also how-to instructions on this site and other sites. V8 or else ...
Post #447980 15th Aug 2017 10:01pm
Ipslore
Jersey 2014 Range Rover SVAutobiography 5.0 SC V8 Barolo Black
Usual culprit to check is the front ARB drop links. Easy to replace.
Post #448000 16th Aug 2017 6:14am
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Drop links are the usual suspect but they are good on mine. It has rattle from the o/s/f wheel whenever it hits any sort of bump, can even feel it with cats eyes.
I have tried ad infinitum to ID it, had it up on ramps, wheel free, leveraged all the ball joints and no play evident anywhere.
Only thing I can think is if the shock has a top bearing that it sits in under the shock tower - that is a typical area for this sort of sounds on normal cars but haven't looked in Rave yet to see if the FFRR has one.
Cheers,
MM 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #448013 16th Aug 2017 9:17am
umitbat
You can hear at 8th and 20th seconds.
It became more like metallic clunk espesially on breaking.
No noise uphill. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #448447 20th Aug 2017 12:08pm
fisha
If thats a gravel type road with lots of little bumps on it, then ball joints imho based on those sounds.
I've tried that too. Couldn't find anything at all. Took the arms and ball joints off, and when in hand the ball joint had about 2mm vertical play in it. The suspension seems to be pre-loaded with force that makes it hard to use a lever to find play. Similarly, when jacked up with the wheel hanging, the arms are at such an angle that they prevent play appearing in the ball joint. V8 or else ...
Post #448491 20th Aug 2017 5:16pm
zarnd
Yup, mine makes a louder version of that noise. Has done for the last 30,000 miles and nothing has fallen off.
Be interested if you find the cause and the cure!
cheers Alex
2007 M5 Touring
2004 SL55 AMG
Post #448539 21st Aug 2017 9:39am
umitbat
Two different mechanics said this noise is due to steering box.
And need to be repaired.
I have no idea about this job,any comments? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #453433 9th Oct 2017 1:43pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
that's exactly what mine is doing too but theres no play or anything in any of the joints and DL are new , its so irritating
Post #453463 9th Oct 2017 4:25pm
