![]() | Home > Technical (L322) > Front bumper removal ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
i used the search function pal and found this,
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
@ bembo449
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 816 ![]() ![]() ![]() |
will download it pal but if we don't ask questions how do we interact with each other ? |
you'll find that the regular members that are on the forum most days might not respond to common questions that can be found easily in the wiki or using the search function , so your question might not be answered pal... ... - .- -.
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Iirc, powerful uk do a face lift video on you tube.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3246 ![]() ![]() ![]() |
Depending on which sensor u r removing, you don't necessarily need to remove the bumper. If it is the end ones, you can replace in situ (long arms and small hands help!) |
Sorted it this aft , turned out to be damaged wiring , but of soldering and they are fully operational again , thanks to whoever suggested the wiring maybe at fault |
