Home > Technical (L322) > TRANSFER CASE BEARINGS, where to buy.
herman maire
Canada
I have the transfer case apart right now, but I am having NO luck sourcing new bearings locally. Does ANYBODY! know where I can source new bearings.
Transfer case model- NV 225
The original part # for the bearing is - Brand name - NSK item#- B47-7a1
I have tried to cross reference with another bearing but no luck.
Any help appreciated.
Post #46410 17th Jan 2011 10:39pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
When I took in my FFRR to have the auto sorted I spoke at length with the owner of the firm (hands on) who did it. He had several FFRR's in to do, one of which had a busted transferbox. He said that he couldn't get the parts to rebuild it Shocked so it was a replacement in that case. He is a transmission specialist so if any one could sort it I would have figured he could.
I hope you have more luck! 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #46419 17th Jan 2011 11:14pm
herman maire
Canada
That just seems wrong.... you think the New venture gear plant ( the plant that built these NV225 ) in roitzsch, germany would send me a few bearings Very Happy
Post #46436 18th Jan 2011 12:16am
elpeede
Its got to be worth a punt... they aren't small change as I'm sure you've already figured out. Other thing to try I guess would be to take all the measurements you can and speak with a specialist. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #46466 18th Jan 2011 10:12am
SteveMFr
Site Sponsor
I believe I read that the transfer case was un-rebuildable in the RAVE too (rubbed me wrong, which is why I remember it. That sort of comment makes me think: F@(K U! You're not getting my money!)
I couldn't find any info on the numbers you provide either. Why not try these guys? They have a rebuild kit for Jeep NV 247 transfer boxes - they may be able to help with bearing sizes. Otherwise, send me a PM and I'll call NV in Germany for you.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
(wife thinks I'm nuts - prob right, too)
Post #46467 18th Jan 2011 10:20am
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
long shot but on the bearing sides outer ring (if that makes sense ) there is usually a number in maybe black that is the bearing spec number if you know that you can get one from anywhere Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #46521 18th Jan 2011 6:54pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
A bearing wont be unique to one application, it will fit a multitude of roles.
Done a quick google and came up with this site.
http://simplybearings.co.uk/shop/
Post #46532 18th Jan 2011 7:29pm
mzplcg
Regarding anything transmission my first port of call would be Dave Ashcroft of Ashcroft Transmissions. If it's at all possible he will know how. (advertises in LR mags)
If Dave says no then my last resort would be Chris at C&K Engineering in High Wycombe. They've made me all sorts of stuff which I couldn't otherwise have got such as white metal bearings etc. If he can't get it he 'might' be able to make it. If he can't make it then, well, it's replacement box time.
Post #46546 18th Jan 2011 9:22pm
