Home > Maintenance & Mods (L322) > Tailgate not latching
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
This just started where the tailgate-metal not glass half- doesn't latch all the time. Need to close it 3 or 4 times. Adjustment , cleaning or it the actuator on the way out? Thanks.
Post #451841 23rd Sep 2017 3:44pm
CS
I'd start by cleaning and lubricating the lock mechanisms, then seeing whether the rods they locate on have become displaced, I think they are on a concentric pivot (if that is the right phrase) and if yes, repositioning so they match up with the locks. Only Range Rovers since 1988
Post #451849 23rd Sep 2017 5:24pm
Flashman
I had this on mine, the plastic finger latches would stick and need manual release (ooooh errrr mrs).
Lots of WD40 etc and wiggling and they are now fine again. I think the they seized up with dirt. Tom
Current Drive
Previous Drives
Post #451851 23rd Sep 2017 5:30pm
doclees
Thanks guy. I had given it a bit of WD40 but will be more liberal and check alignment.
Post #451858 23rd Sep 2017 6:20pm
Flashman
It took several attempts with the WD40 for it to work. After a few weeks of manually wiggling the latches daily it is now back to normal. Tom
Current Drive
Previous Drives
Post #451861 23rd Sep 2017 6:31pm
holidaychicken
I had to take mine apart, clean and lubricate as the WD40 wasn't getting to the sticky part very well but worked great after.
Post #451976 25th Sep 2017 2:31am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I had similar happen to mine, so I did all of the lubrication I could - didn’t work. I then took the panel off to see if a wire was loose etc - my problem was one of the two check straps had started to really rust through and deteriorate and was lying out of line and only slightly stopping the boot from shutting.
Replacing the straps fixed it for me Thumbs Up ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #451984 25th Sep 2017 7:46am
doclees
Thanks all. A little more WD 40 and it seems back to normal. Probably just crap in the mechanism.
Post #452182 26th Sep 2017 8:26pm
