Home > Technical (L322) > 4.4 tdV8 Oil leaks ( other than turbo pipe O rings.)
Baltic Blue
Calling all 4.4 tdV8 owners:
Please could you reply to this post with either a link to an existing post or a very brief description of any oil leak problems.
e.g., Oil cooler leak into water etc
Oil pump crack leak
Any info appreciated
Thanks
B.B. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #451944 24th Sep 2017 5:27pm
mjdronfield
Here's my saga....
Oil/water heat exchanger cracked, in the V of the V8......
http://www.fullfatrr.com/forum/topic35830.html?highlight=major
Censored 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #451949 24th Sep 2017 7:36pm
mpirie
Mine turned out to be a failed rubber gasket between the oil/coolant exchanger.......princely sum of £15 for the gasket, but much gnashing of teeth worrying in case it was more than it appeared.
Mike
Post #452001 25th Sep 2017 9:57am
bishbosh10
Oil cooler in the V failed and was replaced under warranty.
Still chasing a very minor leak but can't find the source at the moment..... Crying or Very sad Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #452018 25th Sep 2017 1:28pm
Baltic Blue
Thanks for the replies gents.
The oil cooler/heat exchanger could take over the number 1 slot when I update my Fault Log next month, especially if I include the "9 more" mentioned in mjdronfields post.
However, given the number of miles trouble free motoring we all enjoy most of the time, I really think we are lucky to own such a great car.
Cheers
Mike. B.B. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #452023 25th Sep 2017 2:05pm
mpirie
Mike,
If it does make it to number 1, I wonder how many oil cooler replacements could have just been down to the rubber gasket? It''s easier for the dealers to replace the whole thing than carry out a proper investigation.
When I did mine, I was waiting for Dan to supply the cooler, but discovered it was only the gasket, thus saving £300.
Mike
Post #452163 26th Sep 2017 6:32pm
Baltic Blue
I agree with your doubts Mike.
I don't know how long it takes to strip it all down and then rebuild it, but if the cooler/ heat exchanger is c£400, then I suppose that equates to about 4 hours at a MD.
Replacing the unit with a new one removes any doubt and let's them charge for parts and labour without anyone able to question them?? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #452181 26th Sep 2017 8:20pm
