![]() | Home > In Car Electronics (L322) > What do you all think of this as a head unit upgrade? |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 835 ![]() ![]() ![]() |
I’ve been looking for a headunit to upgrade mine as the rear compartment gubbins is suffering from incontinence....
I know, that’s what’s convincing me |
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 84 ![]() ![]() ![]() |
My son installed a Pumpkin head unit in his Golf about 12 months ago and it's proved very reliable. It's remarkably OEM looking and was pretty plug'n'play so your install will be a bit more complex but the hifi, phone set-up, reversing camera and general android functionality are all far better than you'd expect at these prices.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
No 4x4 info on the non touchscreen.....
I don’t have 4x4 info on mine but I was lead to believe that you still have the mpg, distance remaining etc still available on the instrument cluster. As far as the clock is concerned you can set it at 12 o’clock with the fuse removal trick.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
you wont go far wrong if you read Pete's how to on fitting an android unit Simon,
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817 ![]() ![]() ![]() |
ive also been looking at replacing mine pal , can get the unit for 259 with steering wheel patch lead but the kit to plug n play the HK amp set up is 300 quid on its own so ive not gone ahead yet |
Thanks Stan, just had a good read through and it all seems rather straight forward.
ok pal , I may do the same then pal , I don't really need a sub in the car anyway , music that doesn't cut out i will be more than happy with |
Hallelujah to that brother |
will be interested to see how that set up looks pal , I was going for a unit that fits in where the original is but that looks tres cool |
Aye tres Bon ______________________________
im trying to picture what the set up will look like pal , the mercs etc have these floating screen set ups these days but not in 10" flavour , I feel the RR dash is big enough to take it and not look odd thow
I think the Range Rover dash is man enough to take it, but I’ll take the new screen measurements and cut out a template then hold it in place just to see how big it really is.
