![]() | Home > Technical (L322) > Super Super Extended Mode? Anyone tried this? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35800 ![]() ![]() |
its in the owners manual..keep your foot on the brake pedal and press the suspension mode button up...(or something like that) ... - .- -.
i was kinda right,
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Will definitely be trying that next weekend.
It reads that its only available "If grounded and auto extended mode has activated" .... |
yes that's why the guy in the video is using a lump of 4x2 - it makes the car think it's grounded.
^ I would say that stretching the bags will put extra load on any rubber that is starting to get brittle. Any minor cracks may tear. Seems daft to lose a bag for a bit of fun its only designed to be used in emergencies.
i agree with Gary...i've read a few previous threads on this and the consensus is that the bags 'could' potentially pop.... ... - .- -.
Aww you guys are killing me with your sensibleness 😀
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Observations:
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742 ![]() ![]() |
Raising the vehicle to maximum only requires higher volume of air in the air-springs, not higher pressures. If the rubber is brittle then its going to fail anyway with normal movement. However the compressor will get hot from working for so long. |
anorakmark Member Since: 18 Jan 2014 Location: Chatham Kent Posts: 121 ![]() ![]() ![]() |
Ground clearance in off-road height is 283mm
