![]() | Home > Technical (L322) > What gear to tow in |
chawks Member Since: 28 Oct 2013 Location: Dorset Posts: 310 ![]() ![]() ![]() |
I put my V8 into sport mode when towing a horse trailer. I found it gives a smoother ride as gearbox not trying to get into higher gear quickly. On a flat road or motorway normal mode is ok but country lanes and hilly areas sport mode much better. |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481 ![]() ![]() ![]() |
I was always under the impression that sport would be better for towing, as like said above it stops the gearbox trying to change up too early.
standupking36 Member Since: 30 Jun 2017 Location: lincolnshire Posts: 76 ![]() ![]() ![]() |
never herd of this before, i'll try at the weekend & see how we go, |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 641 ![]() ![]() ![]() |
Interesting idea and maybe one to try although I don't know what I'd be looking to "notice". For the SC there's no problem with a car on a trailer (so something over 2 tons) in normal D - smooth and easy as always. Mike - MPx
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 568 ![]() ![]() ![]() |
Been towing horse box for years in normal mode, no problems. All up weight with horses around 2.80 tonnes. Drives:
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3668 ![]() ![]() |
Forgot to add this is a TD6 issue only, all other ffrr's have ZF gearboxes which don't suffer in the same way as the french made GM 5L40E cheese box!! Yesterday I couldn't spell Engineer... Today I are one!
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
I've done lots of towing with a TD6 and a 3500kg trailer - often fully loaded. I've done exactly as miggit suggests - take it easy, keep it at around 2000 where there's maximum torque.
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
At least with the newer 2007MY (well at least the TDV8) simply plugging in the towing electrics sets up the car differently. Holds gears longer and stole suspension automatically adjusting. So no real difference.
buffalo4 Member Since: 01 May 2016 Location: Doncaster Posts: 143 ![]() ![]() |
was waiting for... yellow loon pants and purple polo neck... sadly not it seems |
![]() ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8129 ![]() ![]() ![]() |
I wouldn't tow wearing anything else ![]() |
