Home > Maintenance & Mods (L322) > Performance air filters
Provarmint
England 2007 Range Rover SE TDV8 Buckingham Blue
What are peoples thoughts on these? When I changed the oil and filter on my 3.6tdv8, I thought I'll change the air filter aswell only to realise there was a performance filter in the housing albeit very dirty. After replacing with the standard paper element the engine runs smoother and quieter, not a big fan of them myself, wondered what others thought.
Post #454417 18th Oct 2017 1:37pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
I guess on a standard car they aren't really worth having but if you FF is mapped I'd say defo a good thing , getting more air through than a paper equivlant , the free flow design of them does increase noise levels a tad due to increased airflow , I was looking at one for my td6 this morning as it happens
Post #454429 18th Oct 2017 3:48pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Pretty much all diesels run with excess air. It would need to be highly modified to get any improvement.
Also some think that over oiling them can lead to maf sensor issues. Go for a dry foam one if you do go for it.
Post #454466 18th Oct 2017 7:24pm
nino_nino
Bosnia Herzegovina 2012 Range Rover Autobiography Black TDV8 Santorini Black
I had K&N on my for 12~13 K km and felt no difference so went back to dry filters.
Post #454530 19th Oct 2017 9:54am
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
I have heard stories of peoples experiences when using K&N filters and maybe caused by being a bit heavy handed when oiling them.This has resulted in oil vapour being sucked through the MAF, coating the sensor and causing air/fuel mixture errors.
I did use K&N ones on my classic RR (new 3.9 dropped in with stromberg carbs re-jetted).
To be honest didnt notice any difference in performance just a louder sucking sound when giving it the beans.
Personally I would stick with a paper filter.
Post #454610 19th Oct 2017 7:04pm
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Air
Pipercross for me, sadly no change Many thanks
Paul
Post #454614 19th Oct 2017 7:19pm
