Home > Technical (L322) > Front suspension dropping overnight
marcochezzi
South Africa 2011 Range Rover Vogue SE 5.0 SC V8 Fuji White
Hi Folks
So for some time now my 2011 5.0SC Fattie front suspension drops overnight, both sides pretty equally..
This problem was first noted 2 years back when parked outside with temps below 5 celcius, now it drops irrespective of temperature.
I had stripped my front valve block to clean all the o-rings and make sure there is no drier dust causing issues, to no value.
I replaced the front valve block from a scrapped vehicle (same year) and no difference, although I understand the risk being there that the replacement front valve block is faulty as well..
The drop happens with battery disconnected so it is a leak, not an electrical issue.
Fattie has exactly 106K kilometers on the clock..
I have ordered both front airsprings today, just the bellows, not the dampers, but I'm sitting here with that hollow feeling in my nether region wondering if I did the correct thing, or should I have just gone for a brand new valve block??
Is this fault common, can anyone shed a little light on the potential of both airbags leaking at the o-ring seals??
Many thanks and kindest - Marco
Post #454414 18th Oct 2017 2:10pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
there are lots of things that can cause this issue pal , corroded pipework , reservoir leaking but I guess the fact that both are equally dropping suggest the front valve block or related to that part of the system is at fault
Post #454439 18th Oct 2017 5:39pm
GraemeS
Australia
Mine has the same ailment yet has only travelled 65K kms I concluded that the front cross-link valve was leaking to atmosphere so bought a kit. However I only replaced 2 of the 3 o-rings because the smallest appeared too small but that should still have stopped the lowering if the valves had been leaking from both sides to atmosphere. However 1 side could be leaking and the cross-link valve not sealing properly between the 2 sides. The cross-link valve doesn't look to be well designed but good enough for its intended application except if one air-spring leaks over time.
Post #454498 19th Oct 2017 4:40am
marcochezzi
Thanks Bembo, I need to see what is available locally for the valve block..
Post #454499 19th Oct 2017 6:43am
marcochezzi
Graeme thank you, I cannot make out if your valve block repair did the trick for you, please let me know..
Did you purchase the o-ring kit for LandRover or was it from a different supply source??
Crazy as this sounds our local LR charge 20% handling fee on order cancellations, so I will still take the bags as already paid for, as long as they are late year manufacture date, and possibly replace or keep in store.., will probably consider the valve block as well while I am in there, but if an o-ring seal is available for LR then I will first go that way..
Front left front diff output is leaking as well so with everything stripped down I will have an opportunity to replace the axle seal as well, luckily the Fattie is not my daily driver so she can stand on jackstands for a few days extra..
Post #454500 19th Oct 2017 6:49am
GraemeS
Australia
Replacing 2 of the 3 cross-link valve O-rings did not fix mine but perhaps if the 3rd O-ring was changed then it may have. I didn't change any O-rings for the 2 corner valves so I may have another attempt once I've contacted the supplier to question the cross-link valve's smallest O-ring's suitability.
Here is the kit ex UK that I purchased. http://www.ebay.com.au/itm/Discovery-Air-S...2749.l2649
Post #454503 19th Oct 2017 7:22am
marcochezzi
Many thanks Graeme, I will order the o-rings as a precautionary measure, worth a shot at that price, and shelve the project until I get everything together as one lot.
From the little info out there on this specific problem, it seems that unlike the Discoveries or RR Sports, if one splits the various components of the entire front stut assembly, the Fattie front suspension airbag rotates with the steering, so if I understand this correctly the upper strut seals (o-rings) can be prone to wear given the rotational movement between themselves, the physical strut which obviously rotates with steering input, and the upper strut assembly which is fixed, thereby leaking, slowly at first then progressivly worse as further wear sits in..
Anyway, I might be totally wrong, but either way am looking forward to getting my hands dirty in this regard..
Cheers - Marco
Post #454507 19th Oct 2017 8:42am
GraemeS
Australia
Yes, I understand that the o-rings as the top of the strut are problematic due to the swivelling shaft especially on older vehicles but I would expect dropping on 1 side initially and perhaps a year or 2 later the 2nd side too.
The O-ring kit supplier is sure that all o-rings are the correct size as he has sold hundreds of the kits over the last couple of years, so I will revisit mine.
Post #454522 19th Oct 2017 9:53am
marcochezzi
No, seems I was wrong in my analogy, the o-rings simply seal, they do not rotate against the strut, the entire bag rotates with the strut on an upper bearing plate of sorts..
So I went to my local LR dealer to collect the new original bags which include all the varios o-rings and seals, paid the equivalent of approx US$300.00 per side which is not bad..
As preventative measure I am going to order the o-ring set for the valve block but as our postal service is pathetic at best and goods coming in to the country through them can take anything from 2-6 months to get to me, I will ship to Italy and collect from there on my christmas trip to my folks, so the repair itself, potentially including all the control arm bushes and transfercase sideshaft seal etc etc will be sometime early January.
Lets hope this works.. Thanks for the feedback!!
Post #454626 20th Oct 2017 2:11am
GraemeS
Australia
I thought that I had found the cause of mine's front dropping overnight when I found bubbles escaping from one of the pins in the electrical connector on the front valve block. However a new, confirmed not leaking valve block didn't cure the problem but soapy water with the suspension fully extended revealed the cause - one air-spring is porous all the way around near the base.
Post #485136 4th Aug 2018 3:39am
