![]() | Home > Technical (L322) > whistling noise |
| whoami Member Since: 04 Dec 2009 Location: UK Posts: 76
I have exactly the same. Dealer still has the car but are struggling to trace the cause. |
| Java Jungle Member Since: 22 Mar 2010 Location: Monte-Carlo Posts: 420
Yup, same here...it's on the drivers side though.
| woodchip Member Since: 19 Apr 2012 Location: cumbria Posts: 132
Lucky. Its not a silver VSE is it ?. I had the same problem with mine, sold it in the end, the problem was never resolved by anyone. The only way I could make it less was to adjust the hot/cold little wheel thing below the dash vents. |
| iancollins Member Since: 17 Mar 2010 Location: milton keynes Posts: 264
Yup...... Mine too |
| paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422
Can I join this club??...mine too |
| sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613
I have something similar - I reckon it's either something stuck in the vent system or a bearing beginning to go as it only happens at particular fan speeds and usually when turning right thus putting a different stress on the system. |
| shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 511
Very strange, I got this same thing happen to me this morning on the way to Luton. Whistling sound around 75mph and when I turn on AC, the AC had a small whistle and then it all went away (but something smelled bad for 5 mins). Mine happened whilst going in a straight line on motorway.
just to add to my prev post, you just reminded me that in the early days of the VSE the air quality was very poor and stale so much so that it took your breath away and you had to drive on ocassions with the windows wide open or basically die.
| lucky Member Since: 18 Apr 2014 Location: colchester Posts: 87
was out in the car today and no whistling noise to be heard ! maybe there was something stuck in vent earlier - does anyone know whereabouts the aircon intake vent is ? |
I think it's the grill at the back of the bonnet just in front of the windscreen. |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880
a friend has suggested it 'could' be the air filter..might be worth taking it out and see what the result is. ... - .- -.
| Autobiography Member Since: 10 May 2011 Location: UK Posts: 926
I had this problem too. It's something to do with the air recirculation flaps - fix is to turn the 'Auto' mode of the air circulation off. |
Tried that and it makes no difference.
I'm getting mine back from the detailer tomorrow so will test this again and see what happens. MY11 Vogue 4.4 TDV8 - "African Queen" |
