![]() | Home > Technical (L322) > FBH, auxiliary heater |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
I have same year vogue and it has fbh, its fixed to under side of battery tray need to remove wheel arch liner (and battery tray maybe) to get to it. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3246 ![]() ![]() ![]() |
All TD6 and 3.6 TDV8's have the FBH fitted as standard but you need the little actuator box in the rear to make it function and a remote is useful (altho as you say it can be done solely from the OBC)
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 ![]() ![]() ![]() |
Thanks. I did search for anything about the heater but came up with nothing ?? To be fair though, I'm old and don't get on with computer stuff. |
Same here re old and computer stuff, only had this rr two weeks and there`s that many boxes of tricks in the back not got a clue yet what does what ! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7979 ![]() ![]() ![]() |
Same question
