![]() | Home > Technical (L322) > Loud brake groan after brake job |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Nasty, it sounds like the metal disc guard is getting involved or the caliper is loose or pads are loose in the caliper.
Kingstang Member Since: 01 Nov 2017 Location: New Jersey Posts: 11 ![]() ![]() ![]() |
They are aftermarket drilled/slotted/vented rotors, I de-greased them before installing. Anti-rattle clips are in, the set came with everything the factory would come with.....................This is happening on both sides, all I did was change the rotors and pads. I'm stumped!! |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
sounds like the pads and discs are still too new and not bedded in yet. I get a similar sound sometimes after I've washed the car ... it goes away after a few brakes. Have you taken it and done a bed in procedure ?
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
.Kingsteng,
Fellas,
I personally wouldn't worry about it. I just think its stiction from the new materials that still have to bed in properly. Keep us updated to see if it goes once the car has had a bit of a run. V8 or else ... |
Will do Fisha. |
