![]() | Home > Technical (L322) > Low ratio box change motor |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
theres a great 'how to' by joe90 [tim] in our wiki that will help you.. ... - .- -.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
There are only 3 bolts holding it on but you do need to be a bit careful if you took it off as the screw that is turned by the motor locates in the end of the shaft I have shown in red and if you were to push this shaft in and the took out the screw it would be transfer box out but this is unlikely to happen.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
If you flick the switch and get stuck in LOW, it is possible to remove the motor and wind the transfer box back to high ( I use an old motor I took apart).
AJ Johnny Member Since: 30 Sep 2017 Location: Bedfordshire Posts: 79 ![]() ![]() |
Thanks very much chaps, that’s really clear instruction.
Quite common if not regularly used. Search the forum and you will turn up quite a few threads about it.
