Home > Maintenance & Mods (L322) > Change number plate bulb
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Numpty question ...
Do the covers pop off, or do I need to undo the 4 screws near the covers?
Post #457014 12th Nov 2017 12:20pm
GAC23
Just had a proper look in daylight. Thankfully it’s a pop off job Smile
Halfords here I come ...
Post #457016 12th Nov 2017 12:50pm
GAC23
Fitted LED ones.
They look great but ...
... now I’ve got the LED bug Smile
Are the bulbs for the puddle lights in the mirrors easy to change too?
And can I get some with the car’s outline on - like the Evoques?
Post #457024 12th Nov 2017 1:31pm
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Thank you - doing mine as soon as the bulbs are delivered Thumbs Up
Post #457026 12th Nov 2017 1:42pm
GAC23
GAC23 wrote:
Fitted LED ones.
As the reversing lights are rubbish, can I change these for led too?
Any links on where to buy the right canbus bulbs appreciated too.
Thank you.
Post #457034 12th Nov 2017 2:18pm
GAC23
No problem, glad it helped.
Nice to be able to instead of asking questions all the time Smile
Post #457035 12th Nov 2017 2:19pm
holidaychicken
I changed my number plate bulbs for LED and after a while I started getting lots of light faults popping up on the dash but none relating to number plate bulbs and when I finally removed the number plate bulbs to check them they had been over heating and had started to melt the plastic surround and had a very strong smell off burning.
Now I like the look of a bonfire as much as the next man but ....
Post #457106 13th Nov 2017 4:09am
p38arover
Australia
Hmm, I've just changed mine for LEDs. I hope they don't melt the housings.
Re the reversing lights, the illumination comes out the end of the bulb like this BA9s base LED.
ebay item no. eBay Item No. 262693180814
The L322 reversing lights are pretty poor. They really only tell the person behind that one is reversing. They do little to illuminate the area behind the car. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #457107 13th Nov 2017 5:22am
GAC23
Thank you!
Will look for a UK supplier.
Post #457114 13th Nov 2017 10:39am
Sharky1168
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Just got these before the group buy was in place Evil or Very Mad
https://www.ebay.co.uk/itm/H6W-434-BAX9S-C...2749.l2649 at £13.48 free P&P
Still very pleased with the results & I can now see when reversing in the dark! Current RR L322 TDV8 VOGUE
Past: RR L322 TD6 HSE, Discovery 2. Land Cruiser V8, Saab 9-7x, Nissan Maxima, Ford Granada I, II, III
Post #490947 4th Oct 2018 4:28pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Sharky,
Are they not a little long in the body?
The group buy ones are much shorter.
Cheers
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #490949 4th Oct 2018 4:37pm
kbald
I had the same issue with the numberplate lights they got hot and almost started to melt the plastic and they also didnt work correctly after a while and started flashing rather than staying on so wasnt too great.
I also had led side lights and one side got so hot it eouldnt eork and got warning messages and the wire was black and the only way to get it to work was to wire it into the other side one.
Could have just been unlucky but thought id put my experience up aswell of leds so its standard omes for me from now on. Current 2007 TDV8 Vogue Buckingham Blue
Post #490950 4th Oct 2018 4:50pm
DMRR
Prior to my RR expiring on Monday it has been fitted with LED's for 6 years. Every lamp apart from the Xenons was replaced. Had no issues - even got the funky RR projected lamps under the doors. Going to take me a while to transfer them all from the dead one to the new Westminster lol! Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #490951 4th Oct 2018 4:58pm
Sharky1168
Bushy30 wrote:
Sharky,
Cheers
Bushy
They 'just' fit, but it is snug without touching the lens. So far all looks good and they haven't overheated, burnt the lens or melted anything lol. Agree the group buy ones are shorter & have been made for the job, but I purchased these before I had this option...They certainly are a lot brighter Current RR L322 TDV8 VOGUE
Post #490960 4th Oct 2018 5:41pm
Bushy30
No problem, worth keeping an eye on Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #490968 4th Oct 2018 6:10pm
