![]() | Home > Technical (L322) > One headlight is looking at the floor. |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
It's possible the arm that connects the leveling motor to the reflector has detached.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
^Or failing that ^ (which is a good shout |
noworries4x4 Member Since: 03 Oct 2013 Location: Newton Abbot Posts: 166 ![]() ![]() ![]() |
Thanks for the advice, yes the lights test ok and were cornering ok just o/s pointing at the floor. Took the head light out could not see any motors or links through the big hole at the back.
The same as you would adjust the light for an MOT etc... Allen key on the top from memory |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
that image is for normal headlight adjustment craig, noworries has an AFS system so it sounds like the vertical stepper motor has failed ..
I was going to suggest that the headlight adjusters adjust the whole head light assy not just single eye part. Going to look at the wiki section Thanks If everything is under control you are not going fast enough.
Ahh WM workshop manual not Wiki being dense again If everything is under control you are not going fast enough.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 816 ![]() ![]() ![]() |
my drivers side one was aeroplane spotting when I got it , turned out to be one of the mounting rods inside had come adrift , reattached and all was well |
^ that's what happened to mine.
Up-date for the above problem.
Well done, that man!
If I do have to go in there again I will take pictures, as there is as ever an easy way and a hard way. When you first strip one out you automatically head for the torx screws, all this does is remove the surrounds ect. What you need to go for is the white 90deg turn clips, turn these and the light literally falls apart. If everything is under control you are not going fast enough.
