![]() | Home > In Car Electronics (L322) > Fix wear marks on the screen |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
You won't believe it, I didn't, but a baby wipe will remove the rest of the coating and leave the screen looking like new, it takes a bit to do it and to get right into the corners but persevere...... |
| RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 146
Thanks, I'll give it a go once it warms up. |
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3964
long time ago when I had an l322 I did what Pete suggested (worked a treat) then carefully cut down an Apple Ipad screen protector and fitted it (again fine) Geoff |
Baby wipes did the job, along with 10 minutes of elbow grease. Thanks for the recommendation.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
I used Autosol chrome cleaner which worked a treat! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| AlexTVR Member Since: 18 Dec 2023 Location: Gloucestershire Posts: 72
This has to be one of the easiest and best ‘hacks’ for fixing something on an L322. Did mine today, amazing 😁 2010 Supercharged |
| Monty400k Member Since: 21 Oct 2019 Location: Glasgow Posts: 26
What phone mount is this, looks like a Brodit back plate, Ive got one but its down to the left of the heater controls, this is a much better spot? |
It's a Brodit that's made to fit in that location. I find it's better as your eyes don't move so far away from the road. Search for posts by me on this forum, I've shared the link to the model before. |
Perfect thanks! |
| muppet Member Since: 09 Nov 2016 Location: manchester Posts: 91
I have eventually given this baby wipe suggestion a try and it worked a treat, Thanks for the advice, greatly appreciated and it looks like new !! I need more help than most...sorry !! |
Good to hear, it does make a big difference... |
| Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1889
Sorry a bit OT, but kind of related, is womens makeup messing up leather & trim on door handles, arm rests, etc, etc. very difficult to remove! |
