The FBH uses .7 litre of fuel per hour on full power (i.e. When it is bringing the temperature)
And then it uses .34 litre of fuel per hour on part load (when it maintains the temperature)
They will not work if the battery voltage drops below 10.5 volts!
Generally if there is fuel, and power they work, and their mode of operation depends on a lot of factors. Such as outside temperature, coolant temperature, battery voltage, faults logged on the system eta 2006 RR sport HSE
Swapped for 2012 4.4td v8 Westminster Santori black with Ivory leather
BEEN SMILING EVER SINCE
