Home > Technical (L322) > Sat navigation battery drain
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Far from certain but it looks like my sat navigation doesn't turn off. I checked the red indicator light through out the day while the beast was parked and it never went off. So for the time being I pulled the fuse. So why does this happen? Is it the BCM, audio system or just the sat nav at fault? My logic 7 system is toast. Been running on half a radio amp and no secondary logic 7 amp for a while.
Post #458943 29th Nov 2017 9:16pm
doclees
I can confirm the satnav draining battery because it wouldn't go into sleep mode was due to a tested good but slightly aging battery and/or a 75% broken negative battery cable. It sleeps fine now.
Post #472489 13th Mar 2018 8:51pm
Pawl
Always good when faults can be resolved without too much pain - lol.
Well done! Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #472493 13th Mar 2018 9:15pm
doclees
Forgot to add that I did the amp repair with the two cheap amps but it still wouldn't go into sleep mode until the battery/ground repair.
Post #472539 14th Mar 2018 12:59am
