Home > Technical (L322) > FBH FUEL PUMP |
Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190 |
Anyone ? |
3rd Dec 2017 9:30pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
I swapped out my FBH pump about 6 weeks ago as it was leaking. They cost about £220 from Land Rover. In addition to the pump you will also need 2 hose clamps
3rd Dec 2017 10:55pm |
Thankyou andy looks like ill give landrover a call 👍 |
4th Dec 2017 4:53am |
Try Dan @ Duckworth, he was cheaper than my local dealer (Less than £200). Mine was leaking so badly I ended up having to buy it from my local dealer
4th Dec 2017 7:50am |
Thanks andy ive seen a couple from bmw x5’s on flea bay they look the same as mine but its take ya chance on ebay isnt it |
4th Dec 2017 8:12am |
Seem to remember the pump has 'Wabasto' stamped on it so probably is common to an X5, didn't think to check part numbers at the time 56 TDV8 Vogue SE
5th Dec 2017 10:48pm |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 |
Please don’t pay dealer prices. Get one for a webasto thermotop c from eBay. No7 - 2003 V8 Vogue |
6th Dec 2017 5:16pm |
Thanks guys 👍👍 |
6th Dec 2017 5:54pm |
I seen this on ebay from a x5 looks excactly same as mine what do you chaps think
6th Dec 2017 7:01pm |
Thats the badger No7 - 2003 V8 Vogue |
6th Dec 2017 7:13pm |
Brilliant thats £35 |
6th Dec 2017 7:49pm |
Is it just a case of swap it out ? I asume theres no bleeding required |
6th Dec 2017 7:56pm |
Yep, just swap it out. They are self bleeding. It may need a couple of cycles to clear any air. No7 - 2003 V8 Vogue |
6th Dec 2017 8:14pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1286 |
Bumping this Thread to see if someone could take a photo of the FBH fuel pump assembly above the rear diff?
17th Oct 2021 9:51pm |
