Home > Technical (L322) > Facelifting fatty with afs lights.
alistairh
Ok I’m doing a 2004 to 2010 conversion over the holidays and have a question. Both headlights came from different cars and I’m a bit concerned due to the fact they are afs headlights there’s a possibility the headlight aim could be off on each unit..if this is the case can they be manually adjusted? I know nothing can be done via diagnostic but wanting to check prior to stripping car down..
Post #460644 12th Dec 2017 10:13pm
Flashman
The AFS will reset to default position if you give it a default power supply. This means you can use them in non AFS cars. Not sure of which wire you need to supply power to, but it is in the wiki. Tom
Current Drive
Previous Drives
Post #460645 12th Dec 2017 10:24pm
alistairh
That’s all I needed . Many thanks
Post #460654 12th Dec 2017 10:48pm
