![]() | Home > Technical (L322) > FSR and faults |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Gents can a failing FSR cause any other problems - my blower seems to work ok so wondered if it could be failing and causing a battery drain - interestingly if I put the blower on max it has brought on trans failure only a couple of times |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Yes, battery drain is one of the symptoms - but there could be many others....(reasons for battery drain) .
